won't start smell gas
Old Mar 7, 2014 | 09:31 PM
98beater's Avatar
98beater
I replaced the temp sensor on a suggestion from hey you. It took a while I know, but broken leg, cold as hell and no garage don't go together very well. So far it seems to be running fine but idling a little low, but hasn't tried to die and fired right up every time. Thanks for your suggestions everybody.
Old Mar 8, 2014 | 12:45 PM
What is it idling at?
Good to hear it runs again.
Old Mar 8, 2014 | 04:27 PM
98beater's Avatar
98beater
A little above 500 in gear at a stop. I'd be more comfortable with it around 650-700, but it hasn't stalled out. It also idles a little rough sometimes, but I need to re-route the plug wires according to the tab and I think it should take care of it.
Old Mar 8, 2014 | 06:50 PM
Wonder if the tach is just inaccurate......
Should idle right around 600 fully warmed, in gear. So long as it doesn't stall though, its probably good..
Old Mar 8, 2014 | 06:59 PM
98beater's Avatar
98beater
I figured that, and when I put my plug wires on I didn't know about the tsb on them. I'm gonna check fuel pressure while I'm up there, but so far so good. Thanks again for your hwlpy
