Injector info ?
Old Mar 1, 2014 | 12:09 PM
getdown78's Avatar
getdown78
Default Injector info ?
What lb. injectors do the 318 and 360 have ? My trucks old 360 had a pcm that came with it that has been tuned because the 360 had a bigger cam but i was wondering if i could put bigger lb inj in my now 318 and use that pcm to get some more power ?
Old Mar 1, 2014 | 12:30 PM
From what I have read, they are 22lb/hr injectors on both V-8's. Just the programming is a bit different.
You may be able to use the other pcm, but, bigger injectors in and of themselves won't give you any more power.
Old Mar 1, 2014 | 12:40 PM
getdown78's Avatar
getdown78
And my truck doesn't have a cat converter with true 2.25 dual exaust ! It has 4.56 gears front and rear but the 318 i swapped in it just really lacks on power ? I just want a little more out of it ?
Old Mar 1, 2014 | 12:59 PM
What size tires?
Old Mar 1, 2014 | 01:09 PM
getdown78's Avatar
getdown78
34-10.50-16 super swampers on 16x10 wheels !
Old Mar 1, 2014 | 01:17 PM
That shouldn't be an issue then.
Plenum fixed?
There really isn't that much of a power difference between the 318 and 360..... how many miles on the engine? What all has been done to it?
Old Mar 1, 2014 | 01:23 PM
getdown78's Avatar
getdown78
When i did the 360 to 318 swap sept 2013 i put all new gaskets on the motor, new timing set, and water pump ! The 318 i bought was suppose to have about 100k on it and all the bearings looked new when i checked them ! I used the 360 intake with the alum plenium plate and good fel pro gasket and bolts ! When i started the motor it misfired and after checking everything it had bad inj so i swapped them and it ran good !
Old Mar 1, 2014 | 01:29 PM
getdown78's Avatar
getdown78
If the dodge is 22lb then could i use some ford 24lb inj ?
Old Mar 1, 2014 | 02:31 PM
Spillage's Avatar
Spillage
Stock = Siemens 53030778 (EV1) 21.9lb/hr@43.5 PSI (23.2@49psi) 12ohm
I used Bosch #0280155784 (EV6) 22.3lb/hr@43.5psi (23.7@49psi) 12.5ohm
These are 4Port injectors, and you need EV1-EV6 Adapters to plug in the harness.
They're working great for me.
I've also heard of folks using Bosch #0280155703 22.5lb/hr@43.5psi on 360's.
You're not going to need or benefit from bigger injectors unless you have substantial mods that demand it.
24# wouldn't be needed unless you have a stroker.
