Is there a fusible link on the flasher circuit?
Old Mar 3, 2014 | 12:03 PM
rob_tapp's Avatar
rob_tapp
Default Is there a fusible link on the flasher circuit?
I shorted my flashers out. I wired up some new lights on my bumper wrong & it smoked the flasher relay. It did not blow any fuses that I can find. Not in the fuse panel, or in the one under the hood. I spliced into the existing wires going to the flasher bulbs for the new lights. I disconnected the lights I put on & still no turn signals or hazard flashers & I did put in a new relay. I checked the turn signal switch per the manual and everything has continuity when it is supposed to. I think that I am missing something somewhere & was wondering if there is a fusible link in that circuit anywhere?
I have searched quite a bit & havent found anything on this subject. It seems to usually be the multifunction switch or the flasher relay. I am quite surprised that I didnt blow a fuse. With a new relay in there, I get nothing when i hit the turn signal or hazard switch. I am not really sure of the pinouts on the flasher relay, or how to check that thing either.
I had some flashing only lights on my front bumper. The lenses were broken and of course they have changed the style of them. So, when I put the new one on, I screwed it up. I put the hot from the flasher directly to ground on the bumper. Now I am stumped. Parking lights work, brake lights work. Just not anything to do with the relay circuit.
Anyone have any idea how I can chase this problem down? I am not really sure if I have something open what. If it was shorted, I would think it would be blowing a fuse, but I would have thought it would have blown a fuse in the first place.
I would appreciate any tips, as I am kinda stumped.
Rob
Old Mar 3, 2014 | 12:16 PM
Grab the 01 service manual from the Service Manual thread in the FAQ section here. Wiring diagrams are in there.
Check Fuse 4 in the power distribution center. (under the hood) and fuse 10 in the fuse block on the side of the dash.
Old Mar 3, 2014 | 12:34 PM
rob_tapp's Avatar
rob_tapp
Hey Thanks. The downloaded repair manual is way better than my Haynes book. I gives me a good method to hunt down the problem. I think that is going to be a big help. All of my fuses are good, I bet something is open there somewhere. I think I will be able to track it down with that guide
I will post the results when I get it checked out!
Rob
Old Mar 7, 2014 | 10:56 PM
rob_tapp's Avatar
rob_tapp
I got it figured out! It was a fuse in the PDC! I was looking at the diagram on the inside of the cover wrong. I had previously checked all of the small typical automotive fuses. The one that feeds the flashing circuit was the different style engine compartment fuses. I was working from the wrong end of the diagram on the inside cover. I did use the troubleshooting guide in the 2001 service manual and it was really helpful.
HeyYou, Thanks for your help !
Old Mar 8, 2014 | 12:32 PM
Awesome. No more sticking your arm out the window to signal turns!
