Installing an aftermarket temp gauge
Old Mar 4, 2014 | 01:24 PM
PatrioticRam93's Avatar
PatrioticRam93
Default Installing an aftermarket temp gauge
Hello, I am looking into installing an aftermarket temp gauge into my 1997 Dodge Ram with the 8.0 engine. I cannot find out exactly where the gauge has to be hooked up onto the the engine. I was thinking where the stock temp gauge sending unit threads into the thermostat housing but I want to be sure. Any help I can get would be much appreciated. Thanks and have nice day
Old Mar 4, 2014 | 02:20 PM
That would work just fine, provided that it will actually screw in there. Is your electrical gauge not working?
The problem there though is: The PCM also gets its cue from that sensor, and without it, the engine probably won't run....... (PCM will always think the engine is -40 degrees..... and it will DUMP fuel hoping it will burn.)
Old Mar 5, 2014 | 11:38 AM
PatrioticRam93
Here is how it all started. I had to change my thermostat and a couple hoses. When I went to pull the electrical line from the temp gauge sending unit on top of the thermostat stat housing and it broke. So, I bought a new temp gauge sending unit sensor and a coolant temp sensor as well. I figured if I am replacing one, might as well do the other. The gauge was working fine all before this, but now it does not move. I tried my best to run the electric lines back to the gauge to see if it may be grounding out somewhere and I checked all of the fuses in the cab and the engine bay. I am getting nothing.
Old Mar 5, 2014 | 12:07 PM
Wiring diagrams show only one sensor. You have two??
Old Mar 5, 2014 | 02:17 PM
PatrioticRam93
Yes, according to my Haynes manual, there is a temp gauge sending unit and a coolant temp sensor for the pcm. This link should take you to an autozone link that show the top of my thermostat housing.
Old Mar 5, 2014 | 05:38 PM
Ok, interesting. Wonder why they did it that way.......
Are they both two wire sensors? Does it run right? Are the sensors both the same??
Old Mar 8, 2014 | 02:52 PM
PatrioticRam93
No they are not the same. One is long and skinny after the threads and the other is stubby and fatter. The coolant temp sensor has 2 wires running to it and the temp gauge sending unit has one wire running to it. It seems to run fine but I just do not like running it and not know what temp it is at
Old Mar 8, 2014 | 03:50 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
But they're both 2 pin connectors, correct? Did you swap the plugs by accident?
Old Mar 8, 2014 | 04:24 PM
PatrioticRam93
No, one has two pins and the other has one pin.
Old Mar 8, 2014 | 04:45 PM
TNtech's Avatar
TNtech
