Engine swap questions
Old Mar 8, 2014 | 10:05 PM
97tn4x4's Avatar
97tn4x4
So do I just load the truck on a trailer and take it to them and tell them to set it and that's it?
Old Mar 8, 2014 | 10:18 PM
stewie01's Avatar
stewie01
Pretty much. Tell them you need fuel sync set.
Old Mar 8, 2014 | 10:45 PM
97tn4x4's Avatar
97tn4x4
Now I got to find a trailer my truck will fit on. Will it ok to crank it before they set the fuel sync?
Old Mar 8, 2014 | 10:51 PM
stewie01's Avatar
stewie01
Should be ok, just may run rough.
Old Mar 8, 2014 | 11:46 PM
97tn4x4's Avatar
97tn4x4
I just need to be able to pull it on a trailer
Old Mar 9, 2014 | 11:03 AM
if you can get sync close enough for the engine to run halfway decent, just drive it to the dealer. Or whatever shop that will set sync for you.
Old Mar 9, 2014 | 04:49 PM
97tn4x4's Avatar
97tn4x4
How are they set factory, is it just TDC and rotor pointing to number 1? Or is there something different I need to do?
Old Mar 9, 2014 | 05:09 PM
There is a procedure in the FSM. Basically, line up marks on the timing gears, line up the distributor rotor with a mark on the dist, and those both need to line up with a mark on the block. Should get you in the ballpark such that the motor will at least run.
Old Mar 9, 2014 | 05:14 PM
merc225hp's Avatar
merc225hp
Basic fuel sync can be set with a DVM to get it up and running, and how to do that has been posted more times than enough, try a search and see if you can find how it's done.
Old Mar 9, 2014 | 05:50 PM
junkyardjeff's Avatar
junkyardjeff
I might be going from a 5.9 to a 5.2 too so could the 5.2 computer be substituted instead of having the fuel synced,I will be trying to find a complete truck before doing the swap.
