Engine balance ?
Old Jun 16, 2014 | 05:03 PM
  #21
getdown78's Avatar
getdown78
Instead of starting another thread i will use this one ! Will a 180 deg thermostat cause my truck to not build enough heat in the motor to make power or does it need a 195 ? I did swap a 5.2 in place of the 5.9 but also did 4.56s but kept the 5.9 pcm ?
Old Jun 17, 2014 | 03:41 PM
  #22
aofarrell2's Avatar
aofarrell2
180* tstat won't hurt anything unless you are in a cold climate.
Keeping the 5.9 pcm will most likely make the engine run rich, better check your O2 sensor readings. Running too rich will dilute the engine oil, clog the cat, and hurt fuel economy.
Old Jun 17, 2014 | 04:18 PM
  #23
Once the engine goes into closed loop, O2 sensors will correct mixture. No worries.
Old Jun 17, 2014 | 10:45 PM
  #24
getdown78's Avatar
getdown78
It has no cat and dummy O2 sensors !
Old Jun 19, 2014 | 09:50 AM
  #25
You actually want at least the front O2 sensor. Engine runs far more efficiently with it.
Old Jun 19, 2014 | 08:05 PM
  #26
getdown78's Avatar
getdown78
Are they the same sensor front or rear ? I have one i got with a parts buy last yr !
Old Jun 21, 2014 | 05:36 PM
  #27
I think the only difference is the length of the pigtail......
Old Jun 22, 2014 | 11:13 AM
  #28
getdown78's Avatar
getdown78
Would i benefit any gain with a tb spacer ? Flat road is smooth but pulling up hills is really hard !
Old Jun 22, 2014 | 11:27 AM
  #29
Ham Bone's Avatar
Ham Bone
LOL throttle body spacer
Old Jun 22, 2014 | 11:37 AM
  #30
getdown78's Avatar
getdown78
just curious ham bone ? I have heard bad and good so i dont know ?
