freeze plugs
Old Feb 10, 2017 | 01:11 AM
Smal's Avatar
Smal
Originally Posted by dbbd1
Did it fall out, or into the engine? It seems unlikely that it went into the head. If it went into the head, you better pull it and find the missing plug.
It fell down into the block I'm very sure,Any ideas ,A friend told me it would be ok what do you all think ?
Old Feb 10, 2017 | 06:34 AM
Moparite's Avatar
Moparite
The water openings in the head/block are big enough for it to fall into the block. Get one of those little magnets on a flexible shaft and see if you can fish it out.
Old Feb 10, 2017 | 11:27 AM
dbbd1's Avatar
dbbd1
THIS is why I don't do my own major repairs. Sorry, but I think you need to get that plug out of there.
Old Feb 11, 2017 | 01:01 AM
Smal's Avatar
Smal
Well id use a magnet but its a Brass Plug Darn it,I have done Major repairs for a very long time now but have just never had this happen before because I am careful ,well usually
Old Feb 11, 2017 | 09:00 AM
It can't go far..... but, you really should try and fish it out......
Old Feb 11, 2017 | 10:02 AM
racefan41's Avatar
racefan41
if it didn't go far, you could try rigging a section clear hosing or vacuum hose up to a shop vac (I hear duct tape does wonders), and fish around with it to see if it will grab it. I wondering how easy it will come out, this pliers once you get ahold of it though.
Old Feb 11, 2017 | 10:29 AM
dbbd1's Avatar
dbbd1
I don't know where you live, its not in your profile, but I have a small camera that would fit in that drain plug hole. At least you could see (maybe) where it was.
Old Feb 11, 2017 | 10:37 AM
Moparite's Avatar
Moparite
See if you can get small mirror and locate it by looking in the hole. You can use tape if it's dry. Try bending a small hook on a piece of metal like a paper clip then see if you can "hook" it.
