turbocharged gas job
Welcome to DF. For future reference:
https://dodgeforum.com/forum/new-mem...-yourself.html
Moving to the correct section.
Trending Topics
http://www.bionicdodge.com/bionic/in...p?topic=9467.0
you can PM msdnga and he can give you the parts list. I think he stopped his speed shop stuff about 4 or 5 years ago.
He did it with a rear mounted turbo. I would go only 4 PSI unless you are adding rod bolts, head bolts (ARP for both) and redoing your piston rings. You will need new injectors, a 2 bar MAP, a tuner (Both the person and the object) and about a year of trial and error to get it right.
If you have over 80K miles, you should rebuild the entire engine before doing this.
