top end job.
Old Mar 16, 2014 | 07:46 PM
joekool4's Avatar
joekool4
Default top end job.
Kinda random but what should a top end rebuild cost? trucks got 180+ thousand and id just like it to run like new again. if possible. runs pretty well right now, a little rich because of the jegs y-pipe, but hasnt been on the road for a little due to no money and needing a new steering gearbox, 20 bucks for seals vs. too much for a new gearbox(will probably rebuild it myself, how hard can it be to replace seals, lol). BUT tax return coming in i should have a little extra left over for it. depending on how much i get back, id like to get a hemifever tune and the top end cleaned up.
Edit: didnt realize i posted this in the tech section, if a mod could move it to general discussion that'd be great. thanks
Old Mar 16, 2014 | 08:12 PM
AtomicDog's Avatar
AtomicDog
Are you planning to remove and re-install the heads, intake and exhaust manifolds yourself? If so, you can save quite a bit of money. If the heads aren't cracked, typically a valve job and new valve seals are what's needed, along with getting them cleaned. If you haven't already done the plenum repair, this is the time to have it done, too. You will need a top half gasket kit, too. If you do the labor, price the parts, contact a machine shop for the cylinder head work and you will have your ballpark cost for your area.
Also, if you are doing the top half, you should also consider replacing the timing chain and gear set with a good double roller set and replace the water pump, front cover gasket and the harmonic balancer seal, if they haven't already been done.
Old Mar 16, 2014 | 10:10 PM
What kind of budget do you think you are going to have?
Old Mar 16, 2014 | 10:12 PM
Ham Bone's Avatar
Ham Bone
Before you do anything do a dry then wet compression Test and post up the numbers.
Go from that. Don't waste money a bad bottom end
Old Mar 22, 2014 | 10:14 AM
joekool4's Avatar
joekool4
I was planning to do most of the work myself. but i dont know yet what kind of budget i'll have. and i'll definitely do a compression test before anything. thanks
