death wobble
Old Mar 17, 2014 | 08:42 PM
Nope. Only parts that actually hold the suspension in place.
Old Mar 17, 2014 | 09:38 PM
97dakota237's Avatar
97dakota237
So what could it be my ball joints are good my wheel bearings are good an. My tie rods and my trac bar
Old Mar 17, 2014 | 10:55 PM
Need to do a THOROUGH inspection. have a friend help. See what moves, when it shouldn't, and doesn't move, when it should.
Old Mar 18, 2014 | 05:28 AM
RaissiKitten's Avatar
RaissiKitten
If those are all good, I suggest the Steering Gear. I replaced all the ball joints, hub assembly, what not.. still had an issue.. One morning I started to drive to town, and my gear shattered. Locked up.. Couldn't get it out the drive way. I had it replaced, and my truck's steering is amazing now! NEVER drove this good, and no more wobble issue. That gear would bind, cause my truck to feel like it would dive into corners, never held a straight line, always pulled left and then right.. Was a major pain. If that is good, a bad alignment will also cause problems
Old Mar 22, 2014 | 10:12 AM
CPTAFW163's Avatar
CPTAFW163
I had bad death wobble when going about 50+ around turns if I hit a bump. I was told by many on this forum that the steering stabilizer was never the problem. SO, I had the track bar tie rods and upper/lower ball joints replaced. STILL had the death wobble. Then I replaced the shocks. STILL had the death wobble. Then I got 4 new tires (Since everyone on this forum said it was probably the tires since the steering stabilizer can never be the problem. STILL HAD WOBBLE. Then I "replaced" the steering stabilizer (The thing the mechanic recommended in the first place). I put quotes there because I had put on a rancho stabilizer the year prior. WELL, the rancho stabilizer was crap and I put the stock one back on. The stock one is VERY stiff. So go with stock, not aftermarket.
Death wobble cured.
However, I think the steering gear is on its way out or it was adjusted too much when my steering pump was replaced. There is no slop in my steering so if I hit a bump and my hand moves the wheel just a tad, it gives slight bump steer.
Old Mar 22, 2014 | 06:01 PM
Johnn123's Avatar
Johnn123
OP do you have any aftermarket leveling spacers? That could be the cause there, to much stress on track bar causing it to go bad real fast. Id check ALL the ball joints, both hub bearings, track bar, bloody everything real thorough! You shouldnt even need a steering stabilizer IMO, its def not the cause IMO.
