Mini starter?
Old Mar 17, 2014 | 08:27 PM
Gaius's Avatar
Gaius
Default Mini starter?
Anyone know of a vendor that carries the gear reduction mini starters? I need a smaller case starter on my 97 5.8 motor to clear the driveshaft. A 1/2 inch would be great.
Anyone running one?
Thanks!
Old Mar 17, 2014 | 08:30 PM
Smaller than the stock starter? mine is already pretty tiny......Gotta pic of the problem area?
Old Mar 17, 2014 | 08:35 PM
Gaius's Avatar
Gaius
Summit Racing has this: http://www.summitracing.com/parts/pw...ions/year/1997
I have an email in to Powermaster to see if they have a PDF of dimensions.
The bottom case ear/bolt hangs down and the already too-small driveshaft taps it. Can't break the starter off in a large hit in a race...
Old Mar 19, 2014 | 10:19 AM
Gaius's Avatar
Gaius
Talked to Powermaster. The 9533 is shorter, but not smaller diameter, which is what I need. However, he said the 9513 can be clocked. The mounting plate looks like it has a slot with a slip, maybe about an inch of rotation. May fix my clearance issue at least. Better than trying to find a Jeep 5.9 case....
Old Mar 19, 2014 | 06:35 PM
AtomicDog's Avatar
AtomicDog
You might want to check into this starter. It allows for adjustable clocking and is pretty small..
http://www.robbmcperformance.com/pro...r_starter.html
Old Mar 20, 2014 | 09:34 PM
Gaius's Avatar
Gaius
That starter is pretty trick. SInce the motor is along the drive pinion, and I may be able to clock the solenoid up, that may fix the entire issue. Thanks!
Old Mar 21, 2014 | 07:32 AM
AtomicDog's Avatar
AtomicDog
RobbMc has been a contributor on another forum (www.moparts.com) for many years. A buddy of mine purchased one of these starters and was very happy with its adjustability.
