Help Fast Please
Old Mar 19, 2014 | 04:20 PM
ngmillar's Avatar
ngmillar
Originally Posted by snowboundrmk
Yeah they usually don't last longer than that. If you have the money might want to replace it.
Ill prob be able to do it in a couple day or a week when I get payed so hopefully this one is good enough till then
Old Mar 19, 2014 | 04:23 PM
xjarhead69's Avatar
xjarhead69
Healthy electrical on these trucks is very important.
Need to find out why battery not charging.
Next time its running use an DMM to see what voltage is at battery while running.
Dave
Old Mar 19, 2014 | 04:28 PM
jholaway1971's Avatar
jholaway1971
The electrical system is a critical part of the truck running smoothly, with that said I would have the alternator tested or replaced when you get a new battery because I have seen alternators go bad in other cars and trucks and the idiot or check engine light never came on. So if you really think about it everything (coil, computer, fuel pump, etc)is depending on enough electrical power to work properly.
ngmillar's Avatar
ngmillar
Dave
I just had to replace a terminal connector so im thinking maybe i didnt tighten it enough or maybe dirty terminals...I cleaned them up and started charging it so will see what that does let you know how it goes
Old Mar 19, 2014 | 05:48 PM
ngmillar's Avatar
ngmillar
Well I charged the battery some and clean the terminals and got them real tight and everything seems to be doing good so far. Thanks for the help everyone
