Tune-up
Old Mar 25, 2014 | 01:47 PM
vandezande1's Avatar
vandezande1
Default Tune-up
Hi guys want to do a total tune up swap on my 1999 dodge laramie 5.2 2wd with top of the line plugs wires and distributor. still have the factory wires and cap in her since she only has 55000 miles but looking for more performance and better mpg any suggestions on what wires plugs and cap i should use would be helpful...thanks
Old Mar 25, 2014 | 02:07 PM
You should start your own thread in the tech section instead of posting in the OT thread. Moving this post to the technical forum for you.
Old Mar 25, 2014 | 02:38 PM
Autolite 3923's (I think) Good quality 8mm wires, and a cap with brass terminals. No point in spending 15 bucks a plug on the 'rare earth' fellers. Sometimes our trucks just don't like those.
Old Mar 25, 2014 | 02:43 PM
Ham Bone's Avatar
Ham Bone
Yep just about any 2 dollar copper plug will do just fine.
Old Mar 25, 2014 | 05:50 PM
vandezande1
oops sorry new to forum will do next time
Old Mar 26, 2014 | 06:05 PM
JSTMoto's Avatar
JSTMoto
I actually recommend sticking with the OE Champion plugs. I had bought some basic copper plugs spec'd by the parts store (NGKs I think), and they ran fine for ~10,000mi. After that I developed a terrible misfire. Felt like the truck burned another valve.
I picked up an OE Champion set from the dealer, and compared the new plugs to the old ones. There was a noticeable difference in the height of the center electrode; the Champion plugs had a taller electrode that stuck out further. I was surprised to see the difference!
I went ahead and got a new set of Mopar plug wires, cap, and rotor to finish out the service. Figured I'd stick with OE stuff this time around.
Old Mar 27, 2014 | 10:28 PM
BrandonBuc'em's Avatar
BrandonBuc'em
maybe the parts store gave you the wrong plugs. i have ngk in my truck. they do the job and iridium wires. thats like...70 bucks just for wires though. hope this helped
Old Mar 28, 2014 | 08:09 AM
AtomicDog's Avatar
AtomicDog
When I changed out my plugs and wires, I used a set of Autolite platinum plugs and an Accel distributor cap and rotor with brass inserts. For plug wires, I picked up a set of Taylor custom fit 8MM wires from Summit Racing. Since the cap is way in the back and no fun to change, I really wanted the brass inserts in it for longevity.
Also, be sure to get rid of the spark plug heat tubes that are pressed into the head if you haven't already. They serve no good purpose at all, other than to collect dirt and debris around the plugs and allow them to rust out.
