Propeller Shaft U-joint Recommendations
Old Mar 27, 2014 | 07:24 PM
renardk764's Avatar
renardk764
Default Propeller Shaft U-joint Recommendations
I need to replace the u-joints on my rear drive shaft. Engine=390 stroker (will be here soon), transmission - Megaviper - Rear 3.91 with Detroit trutrac. Current ones are probably factory originals with over 270000 miles on them. The parts manual gives V8014733AA which appears to be a Mopar Performance greasable alternative, but I want to make sure whatever I purchase can withstand the power and torque of the new motor. Any suggestions?
Thanks! You guys are a wealth of knowledge and I appreciate all your input!
KenR
Old Mar 28, 2014 | 09:42 AM
Get the best quality greasable joint you are willing to spend the money for. Then, keep them greased.
Old Mar 28, 2014 | 11:35 AM
Ham Bone's Avatar
Ham Bone
Get moogs problem solver series. I have a 360 and I tossed one of the caps on the joints at the trans and it didn't damage the joint at all. Not even a scratch. They are greasable and Not too expensive. I got mine off rockauto.
