Newbee-1997 Ram tranny problem
Old Apr 16, 2014 | 05:08 PM
tom123***'s Avatar
tom123***
Smile Newbee-1997 Ram tranny problem
Trying to find out what it means to have to gently accelerate to make my vehical go into reverse,followed by a mild clunking when it engages. It is a 1997 Dodge Ram 2500 5.9l gas engine. I just put my fluid to the correct level. It was dangerously low. I read on this site that I was supposed to be taking my reading while idling in neutral on the level. That taking measurements while in Park could and or would be faulty. When I followed that advise I found it to be correct and that my fluid level was as I said dangerously low. It seemed to help but didn't come totally back. I put Lucus transmission Fix (one quart in the system plus one quart of my regular oil. Hoping I haven't burn't it up!!!! Would appreciate any advise, or guesses as to what I can do or what I have done. Thanks in advance .
tom123***
Old Apr 16, 2014 | 05:10 PM
djbucky3's Avatar
djbucky3
Welcome to DF tom! Im sure some of these guys will have good answers for you!
Old Apr 16, 2014 | 05:15 PM
Welcome to DF. I'll move this to the correct section.
Old Apr 16, 2014 | 05:29 PM
Does it only do that first start of the day? Or, every time you want to back up?
Additive wasn't a good idea. These transmissions hate that stuff.
Old Apr 17, 2014 | 01:46 AM
T-Ram's Avatar
T-Ram
1st and reverse gear issues are usually internal damage/wear-other gears can be a sensor or overdrive issue-Get to a transmission shop that will give you a free diagnosis-if you cant afford to repair it-change ur filter and oil at the least-reverse can go out and u will still have all your front driving gears-fun time trying to remember not to park ina spot that u need to reverse out of though
