Timing chain which one?
Old Apr 21, 2014 | 11:47 AM
sam3293's Avatar
sam3293
Default Timing chain which one?
I'm placing an order with rockauto today. Figured I should order my timing chain as well since I'll save on shipping a bit.
99 dodge ram 1500 5.2l ext cab.
Not sure which one though.
Cloyes double roller
9147 or c160
Also if there is anything else i should do while I am in there?
Thanks for the help
Old Apr 21, 2014 | 02:24 PM
chromed95's Avatar
chromed95
9147 or c160
Thanks for the help
I can't offer much help on which timing chain, I'm sure either would work. But whichever one you go for, make sure you get the appropriate gears as well. Make sure you don't tear up the oil pan gasket taking the timing cover off, or you will taking the oil pan too As far as other things, you'll have the water pump off so depending on the condition of that, you could replace that and maybe that big bypass hose at the top of it that goes into the intake. How's your serp belt?
Old Apr 21, 2014 | 03:38 PM
sam3293's Avatar
sam3293
SERPS under 2 hrs had to get rid of that squeal.
My intake manifold was just replaced two months ago so the hose is all good. Wish I had done this at the same time.
Old Apr 21, 2014 | 04:41 PM
aofarrell2's Avatar
aofarrell2
The difference between the two is the chain pitch. The C160 says heavy duty. As far as which chain pitch I've never seen that before so I couldn't help there. I would recommend calling RockAuto: They have great help and should be able to help you choose.
Old Apr 21, 2014 | 06:14 PM
sam3293's Avatar
sam3293
I called them before I posted they said i should search the forums.
Old Apr 21, 2014 | 06:25 PM
Spillage's Avatar
Spillage
I'm using the Cloyes C3028X double roller timing set on my 98 5.2l.
C160 is a chain only... I wouldn't try to mix and match stuff... do it all new with a matched sprocket & chain timing set.
Old Apr 21, 2014 | 07:03 PM
AtomicDog's Avatar
AtomicDog
As stated, be sure to get a double roller timing chain and gear set. I also installed MOPAR Performance timing chain tensioner part # P5007709, when I replaced my chain set. You can find it here:
http://www.summitracing.com/parts/dc...Fcx9OgodkgQA4Q
Regardless of what timing chain set you purchase, the chain will stretch over time. The tensioner will take up that slack and keep the timing rock solid for a very long time.
Old Apr 21, 2014 | 07:33 PM
xjarhead69's Avatar
xjarhead69
Use the Cloye's 91103, best option for the street.
These sets feature cast iron cam sprockets, 3 keyway induction hardened, billet steel crank sprocket, .250 TrueŽ Roller chain. These, combined with our precision CNC machining offer unmatched quality in its class.
  • Cast Iron Cam Sprocket
  • Induction Heat-Treated, Billet Steel Crank Sprocket (3 keyway)
  • TrueŽ Roller Chain with .250" Diameter Rollers
  • Set is 100% Made in USA
Dave
