2001 5.2L Rough Idle/ Surging
Old Apr 22, 2014 | 02:56 PM
mcmurdo64's Avatar
mcmurdo64
Default 2001 5.2L Rough Idle/ Surging
My 2001 ram 1500 ( 115,000 kms) has been idling rough and surging at highway speeds recently. It has had a rough idle (RPM's rise and fall constantly) since about October. The surging at highway speed started about a month a go. At first the RPM's would surge for a moment and return back to normal when driving at a certain speed with the cruise control on. Now it surges whenever the cruise control is engaged, but is more noticeable at higher speeds. Any ideas what might be causing this? Could this be the TPS? I also had some fuel issues when it was around -30C (ice in the fuel lines) Could this also be related?
Old Apr 22, 2014 | 10:10 PM
ReadRam's Avatar
ReadRam
Most likely a failing TPS. When mine went, it was doing 200-300 rpm surges, cruising and at idle. No CEL either.
Old Apr 23, 2014 | 05:47 PM
mcmurdo64's Avatar
mcmurdo64
That sounds exactly what mine has been doing. I had thought it was the TPS but wanted to get some more input before i drove into town to pick one up. Thanks for the help!
Old Apr 23, 2014 | 08:46 PM
ReadRam's Avatar
ReadRam
A rough idle,aside from the surging, may be other issues,ie tuneup. Remember to disconnect the negative cable on your battery when replacing any sensors. A dealer provided part would be ideal, quality wise, but that's your call.
Old Apr 23, 2014 | 11:28 PM
mcmurdo64's Avatar
mcmurdo64
Hoping the TPS will solve it, but time will tell. Should know by Friday if i can find a TPS tomorrow.
Old Apr 24, 2014 | 10:08 PM
mcmurdo64's Avatar
mcmurdo64
Changed the TPS today and the truck is running better than ever. Starts up better, no surging at idle or on cruise. Even seems more responsive. Thanks for all the help there ReadRam.
Old Apr 25, 2014 | 10:24 PM
ReadRam's Avatar
ReadRam
Glad it worked out good for you. Is that an aftermarket billet grill as opposed to the honeycomb style most trucks have?
Old Apr 27, 2014 | 02:53 AM
mcmurdo64's Avatar
mcmurdo64
Nope, just the stock honeycomb style...in the pic its filled with snow from an overnight blizzard lol
