smoking!!!!
Old Apr 23, 2014 | 06:27 PM
Firstdodgeram12086's Avatar
Firstdodgeram12086
Default smoking!!!!
new to this dodge truck world. i traded my pt cruiser for a 1995 dodge ram, texas truck. it has a 3" sky jacker lift and 4 " body lift. id say id did okay, except this thing smoks like crazy. ive done oil treatments/changes. i have a throttle body style intake. is there something i should be looking for. is there a sure fire way to tell if it is rings or the valves are sticking ??
help the newby!!
Old Apr 23, 2014 | 06:51 PM
Welcome to DF!
First, have a look down the throttle body. See oil pooling in there? Time to do the plenum. (which it is probably past time in any event. read the stickied thread at the top of this forum for more info on that.
Next, do a compression, or cylinder leakdown test. Leakdown is more informative, but, requires the right gauge set, and a source of compressed air. Either one will give you an idea of what kind of condition your motor is in.
Old Apr 23, 2014 | 08:22 PM
kejobe's Avatar
kejobe
First off, is it blue smoke? Black? White? All the time? Or just at start up?
Blue is oil, go HeyYou's route. If it smokes at start up, probably valve seals. Consistently, probably rings and/or plenum.
Black is running rich (too much fuel).
White is coolant. Usually head gasket.
