Blinkers not working....
Old May 2, 2014 | 12:17 AM
DodgeRam10's Avatar
DodgeRam10
Default Blinkers not working....
So my blinkers decided to quit working, left or right, nothing happens, no flash, the light doesn't even come on at all. If I turn the hazards on,all the lights work so I know the bulbs aren't bad. Swapped the turn signal fuse,no change..any ideas?
Old May 2, 2014 | 09:28 AM
Replace the flasher unit in the fuse block on the side of the dash. Your truck should have two, one for the flashers, one for the turn signals. Should be labeled on the inside of the cover.
