intakes
Old May 8, 2014 | 08:40 PM
Firstdodgeram12086's Avatar
Firstdodgeram12086
Default intakes
i have a 360 5.9l with a intake that dose not have the plenum pan. Now, that motor is blown up. i have found a running motor that i want, it has high miles but started up and sounds good. this motor has what i think is the older high rise intake. my question is can i puy my intake form my old motor on the new old motor without much work other then changing gaskets???? please help.
PLEASE HELP THE NEW GUY!!!
Old May 8, 2014 | 08:45 PM
Probably. What are the motors out of, and what do the intakes look like? What year are the motors?
Old May 8, 2014 | 08:49 PM
Matt Nickerson's Avatar
Matt Nickerson
All 5.2s and 5.9s (gas) have the same intake (besides egr and vacuum port locations), there's no "high rise" intake. There is however an aftermarket single plane intake made by Mopar (m1 intake) or Hughes (airgap). These intakes are much better than stock in that they lack a plenum pan and gasket, which is common failure point on our trucks.
What truck are you getting the new motor out of? And is the new one a 5.2/5.9 motor?
Old May 8, 2014 | 09:58 PM
Ram Driver's Avatar
Ram Driver
If the motor your getting has the original kegger intake on it, the intake from your engine will work. Just replace all the needed gaskets and your good to go.
Old May 8, 2014 | 10:05 PM
AtomicDog's Avatar
AtomicDog
I did that type of an intake swap. I picked up a used 1998 5.9 Dakota motor and swapped it into my 1996 truck. I used the intake off the 1996 5.9 motor without issue.
If you decide to do the swap, be sure to do a few other things too:
. install a new double roller timing chain and gear set and water pump
. Replace all of the freeze plugs (1-5/8" in block and 1-1/4" in heads)
. Replace the plenum gasket on the intake
. install a new distributor cap and rotor (both with brass inserts)
. Consider dropping the oil pan and installing a new oil pump and screen
Doing these things while the motor is out of the truck makes for a more trouble-free motor after the swap.
