High pitched whistle coming from cab. WTF..
Old May 9, 2014 | 12:40 AM
98Dodgeram360V8Mag's Avatar
98Dodgeram360V8Mag
Default High pitched whistle coming from cab. WTF..
I have a whistle coming from the cab of my truck that is definatly not audio related. It is really noticeable and goes away when the gas pedal is pressed. It is becoming really annoying and I would like to know what it could be. Thanks.
Old May 9, 2014 | 09:00 AM
CSDavies26's Avatar
CSDavies26
Check the large circular gasket where the air intake tube connects to the throttle body...those have been known to rot away and cause whistling sounds at certain engine rpms.
Old Jun 12, 2014 | 12:54 PM
98Dodgeram360V8Mag
Yeah it's not that because I replaced it about 2 years ago and I looked at it and its fine. It sounds like it is coming from somewhere in the passenger side of the dash.
Old Jun 13, 2014 | 09:27 AM
CSDavies26's Avatar
CSDavies26
Only other thing I can think of would be the vent hose that runs from the air tube to the valve cover on the passenger side. When I first bought my truck, mine was split...wasn't causing any sounds yet but I fixed it anyway.
Old Jun 13, 2014 | 01:46 PM
98Dodgeram360V8Mag
Hmm. This is very weird.
Old Jun 13, 2014 | 01:56 PM
Arde's Avatar
Arde
It's a vacuum leak somewhere. You say it's inside the cab, check all the vacuum lines in the cab for a split. Try the different vent positions to see if all are working OK, might help narrow it down. Goes away when you step on the gas because manifold vacuum drops then.
Old Jun 13, 2014 | 05:05 PM
98Dodgeram360V8Mag
Okay, I will start checking around. My dad said that's what it could be also.
Old Jun 13, 2014 | 05:06 PM
98Dodgeram360V8Mag
And my truck has a power issue. Especially in OD. Could fixing the possible vacuum leak fix my power issue? I have heard that vacuum can do some weird things.
Old Jun 13, 2014 | 05:07 PM
It won't hurt in any event. Have you fixed your plenum yet?
Old Jun 14, 2014 | 11:36 AM
98Dodgeram360V8Mag
No. I don't think it is bad because I looked in the intake and there wasn't any oil or anything dirt related. It was as clean as a whistle. And I have done a couple tests on it such as spraying PB Blaster and smoking the whole intake and the rest of the motor and lines and the only thing that had smoke come out of it was the air box.
