Transfer Case Remval in Drive way, Bad idea?
Old May 15, 2014 | 05:56 PM
jmhd1989's Avatar
jmhd1989
Default Transfer Case Remval in Drive way, Bad idea?
So i am resealing my transfer case it is leaking pretty good. I got the new seal on the transmission side and the transfer case side and the output shaft seal. Dealership said that's all i need. I am also cracking the case to re seal it there as well. I am doing this in the driveway and wondering if that is going to be doable. don't have a trans jack either just jack stands and i regular floor jack. Any other seals i need also?
Old May 15, 2014 | 06:30 PM
Ham Bone's Avatar
Ham Bone
I've done it. You can handle the t case by yourself
Old May 15, 2014 | 09:02 PM
Moochoff's Avatar
Moochoff
I'd do it
Jake
Old May 16, 2014 | 09:02 AM
Be sure to block the wheels, so your truck stays put.
Old May 16, 2014 | 10:30 AM
Wildman4x4nut's Avatar
Wildman4x4nut
Veteran: Army
I've regeared my axles in a dirt driveway. As far as not having a tranny jack you don't need one. You can lift the t-case on your own. The case halves are machined so technically it doesn't need to be sealed. I try to put a light coating all the way around and then let it sit for 5-10 minutes before I put the cases back together. Make sure you check your rear driveshaft for any burrs that could damage the new seal.
Old May 16, 2014 | 11:14 AM
jmhd1989's Avatar
jmhd1989
Thanks guys ill plan to do it then. Thanks for the tips as well
Old May 16, 2014 | 11:28 AM
jmhd1989's Avatar
jmhd1989
And to do that i just put everything in neutral and spin it by hand to feel for them correct? And if it feels like there is is the only option replacement?
Old May 16, 2014 | 11:45 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Additionally make sure you mark the bolts on the drive shaft to the tcase and differentials so that you reinstall the same way. You can introduce balance issues if you clock it differently at reinstall. New vibrations....
If new driveshafts are being put in, then this is not a concern.
Old May 23, 2014 | 10:21 PM
jmhd1989's Avatar
jmhd1989
Doing the transfer case tomorrow morning, ill let you all know if it goes smoothly. Any last min. tips?
Old May 24, 2014 | 11:17 AM
Be careful.
