1997 ram 1500 wont start
Old May 16, 2014 | 07:46 PM
dodge 1500 238's Avatar
dodge 1500 238
Angry 1997 ram 1500 wont start
my 1997 dodge ram 1500 wont start I know water went from the fuel tank it bogged and died and after this it would only run at idle when you start it cold if you go to give it gas it dies and now it wont start at all
Old May 16, 2014 | 08:45 PM
Ham Bone's Avatar
Ham Bone
it wont start can cover so many symptoms. Need more to go on.
Does it turn over?
does it just click loudly?
Does nothing happen at all.
need fuel air and spark to run an engine. From what you said about water it sounds like you have a fuel issue. Did you purge or clean the system somehow?
like i said, need more to go on.
Old May 16, 2014 | 09:00 PM
More info please.
Old May 16, 2014 | 09:03 PM
stewie01's Avatar
stewie01
Probably isn't as simple as this but do make sure the battery cables are tight and clean.
Old May 17, 2014 | 11:38 AM
dodge 1500 238
yes it still turns over and when it wants to run it kinda has a clunking sound to it has spark and is getting fuel and I did not clean the system
Old May 17, 2014 | 08:20 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
water in fuel. water settles in the bottom of the tank pump picks it up.
T-Ram's Avatar
T-Ram
Not understanding the water going through the fuel thing--did you submerge the truck?
Old May 17, 2014 | 08:26 PM
i4got68's Avatar
i4got68
Water can easily get into a gas tank. No matter how hard you try to prevent it
