transmission question
Old May 19, 2014 | 10:47 PM
tbird2017's Avatar
tbird2017
Default transmission question
Will a 360 transmission work behind a 318? If so what do I have to change? Both are automatics and 4 wheel drives.
Old May 20, 2014 | 10:21 AM
Arde's Avatar
Arde
What year is your truck and donor truck?
Old May 20, 2014 | 11:26 AM
tbird2017's Avatar
tbird2017
My truck is a 1995 1500 and the donor truck is a 2000
Old May 20, 2014 | 12:23 PM
Arde's Avatar
Arde
Transmissions don't interchange. You need a 46RH, the 2000 is a 46RE. The 46RE will bolt up, but there's no practical way to make it work in your truck because of the differing electronics.
Old May 20, 2014 | 01:28 PM
xjarhead69's Avatar
xjarhead69
Arde is right. The 95 has mechanical governor and the 2000 is electronic control.
You need 95 or earlier 46rh transmission.
Dave
Old May 20, 2014 | 02:36 PM
tbird2017's Avatar
tbird2017
thanks!
