Leakding output shaft seal
Old May 19, 2014 | 02:51 PM
rludym's Avatar
rludym
Default Leakding output shaft seal
Hi,
I have a leak on transfer case output shaft seal. Is this as easy to replace as it looks? do I need special tool to remove/install a new one. This has a tear causing the leak on the bottom side. Thank you!
Old May 19, 2014 | 03:19 PM
BlindU's Avatar
BlindU
found out I have the same leak as well, so i'll be watching this thread!
Old May 19, 2014 | 03:32 PM
frankie_b_jr's Avatar
frankie_b_jr
Yes, it as easy as it looks. The part you see with the tear is just a dust boot to protect the seal lip.
Old May 19, 2014 | 03:56 PM
rludym's Avatar
rludym
so just a screwdriver will remove it?
Old May 20, 2014 | 02:10 PM
frankie_b_jr
Yup. Take the driveshaft out, pop old seal out, tap new one in, put driveshaft back, and check fluid level ( atf +4).
Old May 20, 2014 | 03:44 PM
rludym's Avatar
rludym
yikes, I cannot get the damn seal off!! This is a New York truck with lots of rust and I was hoping I could get out without having to buy a seal puller but that thing is in there. Nothing is easy!
Old May 20, 2014 | 03:46 PM
dodgister's Avatar
dodgister
Try with a screwdriver, it may take care of it.
Old May 20, 2014 | 06:15 PM
rludym's Avatar
rludym
utterly destroyed it but finally got it out
Old May 20, 2014 | 06:19 PM
That's what usually happens.
