Steering Stabilizer Help
Old May 20, 2014 | 07:06 PM
hometheaterman's Avatar
hometheaterman
Default Steering Stabilizer Help
I need a new steering stabilizer on my 2001 Dodge Ram 1500. I didn't want to spend the money on a dual setup as I'm only running 33"s and have never had a major problem with the factory one on there. I wanted something a little better than the factory one though and looking online it looked like Skyjacker H7017 was what I needed. Well, I got it today and it has the eyelet on the one side that slides into the bracket on the axle and the bolt runs through it. However, the other side also has an eyelet like you'd put in a bracket and run a bolt through. The factory setup here had a shaft on a joint coming out of it, like you'd see on a ball joint or similar. It ran through the tie rod and had a nut holding it on. This one obviously can't do that. Do I need to send it back and just get a factory one, or can I just find a bolt that will fit and stick it through the eyelet on the shock and and put a nut on it on the other side of the tie rod. I'm assuming it won't pull the bushing out, but I'm not 100% sure.
What do you guys think? Is there a different one I need to get, or should I just get a Monroe or similar replacement that's setup like the factory one? Any suggestion on which part # to get? Thanks guys.
Old May 20, 2014 | 09:17 PM
Ham Bone's Avatar
Ham Bone
I wouldnt even bother with one honestly.
There was a big argument a little while ago. But they CAN hide other steering issues.
If you must have one just get a stock style one.
Old May 20, 2014 | 09:42 PM
AtomicDog's Avatar
AtomicDog
I'm running 285/75/16 tires along with a Rough Country steering stabilizer/damper (factory style HD replacement steering damper), a Borgeson steering box and a steering stabilizer - links to the stabilizers are noted below:
http://www.roughcountry.com/steering...-87323-20.html
http://www.custom-diesel.com/cummins...tabilizers/4wd
I'm very happy with my steering using these parts.
Old May 21, 2014 | 07:00 AM
RDuck's Avatar
RDuck
Ya. Big argument.
You trying to cause ****?
End this thread and figure it out on your own.
Old May 21, 2014 | 09:37 AM
CSDavies26's Avatar
CSDavies26
If you go to advance auto, they may even offer a heavy duty stabilizer as well as the stock Monroe version...I know that there was a heavy duty option available for my jeep back when I wanted a bigger stabilizer for my lift. I think it might even be a moog brand one...
Old May 21, 2014 | 10:03 AM
dodgister's Avatar
dodgister
I looked up online, the price range is very wide. Why such a big difference in prices?
Old May 21, 2014 | 10:53 AM
CSDavies26's Avatar
CSDavies26
Different brands....different countries of origin...moog tends to be very overpriced from places like advanced auto or autozone...have you tried rock auto? The beefier stabilizers are going to be more expensive though. Just remember, you get what you pay for when it comes to truck parts.
Old May 21, 2014 | 06:00 PM
nvrsftram's Avatar
nvrsftram
I just replaced my track bar and installed a new skyjacker steering stabilizer and it basically was just a long bolt with a fat spacer and a nut to go on the tie rod.
Old May 21, 2014 | 08:15 PM
MaxPower1971's Avatar
MaxPower1971
Originally Posted by RDuck
Ya. Big argument.
Thank you for making me spit my drink on my monitor. Thank you very much for that.
Old May 22, 2014 | 06:46 AM
RDuck's Avatar
RDuck
Ahh your so welcome eh. Lol.
Putting useless stabilizers on a truck.
The last topic clearly showed everybody should remove them. Even factory installed ones.
Laval. Im from Pointe Claire.
