2500 Stalls when taking turns
Old May 21, 2014 | 12:09 PM
GuysRam's Avatar
GuysRam
Unhappy 2500 Stalls when taking turns
i have been reading that this is a big problem for the 2500. I have a 2001 Ram 2500 and I just recently purchased it. It stalls when it idols and also when I make a turn. Does anyone have a solution to the problem?
Old May 21, 2014 | 12:15 PM
tincan57's Avatar
tincan57
The experts will chime in, but I had a 98 Ram 360 4x4 do the same thing and it was diagnosed needing an Idle Control Valve. I had it changed and it cured the problem (inexpensive too). But I also had a 2500 that the torque converter bellied up, symptoms different of course (fixed). K.
Old May 21, 2014 | 03:04 PM
GuysRam's Avatar
GuysRam
Awesome I will look into it, its sucks that I just picked this truck up too. Oh well you want what you want.
Old May 22, 2014 | 09:00 AM
GuysRam's Avatar
GuysRam
Default Update
On the way home from work last night, blew a fuel line. I had been at Advanced Auto trying to work through some of the things suggested on the form. I guess it narrows down the culprit, there was a lot of pressure built up in the tank when I popped the gas cap off, not sure what that means as I am just getting my hands dirty. If anyone has suggestions, the truck is at the shop right now and would love to know before hand, so I can be on par with my Mechanic
Old May 22, 2014 | 09:56 AM
Some pressure is normal. (especially as it gets warmer throughout the day.) Excessive pressure would indicate a failure in the Evap system.
Old May 22, 2014 | 10:05 AM
GuysRam's Avatar
GuysRam
Thanks HeyYou!
