ABS light need help
Old May 21, 2014 | 07:55 PM
BigGreenRam's Avatar
BigGreenRam
Default ABS light need help
ABS and brake light came on today on the hwy I went to passing gear doweshifted fine then the lights came on I just got done doing the LSD clutches like 3weeks ago could it have happened while I was running 95 mph for a short time. I'm thinking the sensor in the differential is bad any and all help would be great thanks oh one more thing the brakes have been acting up a low speeds under 10 mph hard peddle then goes away works fine WTF!! Lol
Old May 21, 2014 | 09:33 PM
You have RWAL, or 4WAL?
May have a vacuum leak..... or, both problems may be related.
Old May 22, 2014 | 06:03 AM
BigGreenRam
RWAL I came out this morning drove to work bout 15 miles lights never came on
Hmmmm well ill just wait and see thanks hey you
Old May 22, 2014 | 10:05 AM
Sometimes the system will get confused if you spin a tire...... not the greatest system.. pretty much useless as far as I am concerned.
Old May 23, 2014 | 08:08 PM
BigGreenRam
I guess oh well got the new sensor today long weekend ill have time to get it put in thanks oh let me ask u bout a 2 " leveling kit t h ere is some talk about the front end will be all out of whack like to far back and to one side true or bull and have a great weekend thanks again
Old May 23, 2014 | 08:30 PM
2" level should be no problem at all. Lots o' folks do that, with zero problems.
Old May 31, 2014 | 08:16 PM
zach01's Avatar
zach01
2in leveling kit will push your axle back slightly but nothing major I have 2.5 on my 2500 with 35s and stock control arms and no rubbing
