a few months back my airbag light came on temporarally and i noticed the power windows and blower motor weren't working. i turned off the ignition and waited a minute. then started the truck back up. the airbag light had gone off, now my power windows and blower motor were functioning again.
the incident happened a few more times over the next few weeks, and each time the airbag light came on the power windows and blower motor did not function. now the airbag light stays on permanently and of course no windows or blower. any ideas? thanks..
close
- Join DateApr 2010
- LocationClayton MI
Liked:4,223 Times in 3,915 Posts
Only thing I see that all three systems have in common is Fuse 2, in the power distribution center. (black box behind battery, under the hood.)
Quote:
i know it doesn't make since.. i'll check the fuse thoughOriginally Posted by HeyYou
Quote:
Try changing the fuse, I've had fuses that looked good, checked out fine for continuity, but still didn't work.Originally Posted by rapidtransitric
Quote:
not the case some how airbag circuit is shutting down power to the p/w and blower circuit as there is no power coming in to p/w fuse cavityOriginally Posted by Arde
