2000 ram 4x4 driveshaft/rear help
Old May 24, 2014 | 01:02 AM
moparmoneypit's Avatar
moparmoneypit
Default 2000 ram 4x4 driveshaft/rear help
I blew my 3.55 rear end and my driveshaft broke at the ujoint as well as broke the flange. It slid out and the beast crept home in fwd. Breaking the rear completely I swapped axles already but in the original breakage the driveshaft flange went missing. I still have the slipyoke and shift but i can't get it balanced or pressed until i find this part! Can I use Spicer 2-2-1379? I've looked all OVER the Internet and cannot get the straight answer(besides it being a Ford part). I need it as it is my last step to the road. I will be so appreciative. ..i can swap an axle but i can't find the answer!
Old May 24, 2014 | 10:53 AM
Arde's Avatar
Arde
Here is all the info. you'll need on Spicer flange yokes. Might be able to get one from a JY, or a good driveshaft shop should be able to fix you up.
Old May 24, 2014 | 11:10 AM
Might be able to get the whole driveshaft from the yard as well, and it would probably end up being cheaper.
Old May 24, 2014 | 11:11 AM
moparmoneypit
A Spicer 2-2-1379 is $30 on amazon
Old May 24, 2014 | 11:14 AM
And how much is balancing/straigthening your old driveshaft?
Old May 24, 2014 | 01:55 PM
moparmoneypit
Machine shop here will press and balance for $66
Old May 24, 2014 | 03:11 PM
That's actually reasonable.
Think I would still check the local yards. I picked up a complete two-piece driveshaft for a chevy I was working on for 30 bucks.
