Transmission question
Old May 24, 2014 | 09:35 AM
simple jack's Avatar
simple jack
Default Transmission question
I have noticed recently that my transmission (automatic) is not shifting smoothly when I come from a stop. usually 1st to 2nd, (around 3000-3500 rpm) and when it does it shifts hard. I have a 2000 1500 off-road). Should I be expecting my transmission to go belly up or is there a simple solution?
Old May 24, 2014 | 10:26 AM
Arde's Avatar
Arde
Adjust your TV cable. The adjustment procedure is in the FSM you can download from the FAQ/DIY section.
Old May 24, 2014 | 08:19 PM
Dakota1089's Avatar
Dakota1089
Hey jack, I'm no expert so deff listen to these guys but i just wanna share my same experience with my tranny over the last few days.
Same this would occur mainly during cold operation it would either shift kinda hard from 1>2 or not want to shift at all until warmed up a bit. I just dropped my pan today and did filter and added ATF+4 to it and shifting seems back to normal and a lot smoother overall through gears. And it was also around the same rpm as you... But i would start where arde suggested GL
Old May 26, 2014 | 08:19 PM
simple jack
Awesome. Thank you guys
Old May 28, 2014 | 02:52 PM
simple jack
Do you think a trans fluid change would be a good idea? I couldn't find where to adjust the tv cable. I'm not to good when it comes to using this google machine. Can you post a link?
Old May 28, 2014 | 02:53 PM
simple jack
My fluid is full and pink (no grit).
Old May 28, 2014 | 03:41 PM
Arde's Avatar
Arde
Link to the FSM. You'll find the adjustment procedure in there. Don't know what page as I only have the '95 manual.
Old May 28, 2014 | 08:06 PM
simple jack
i drove it around today, no issues. (its not my daily driver anymore due to not good mpg's) im going to drive it to work tomorrow and see if it does it again.
