Oil pressure questions
Old May 26, 2014 | 12:15 PM
Dakota1089's Avatar
Dakota1089
so when cruising, the fact that I have pressure around 60 implies that my internals are in good shape? assuming the gauge isn't messing with me?
Old May 26, 2014 | 12:59 PM
Correct. At least as far as bearings and such goes.
Old May 26, 2014 | 01:12 PM
Arde's Avatar
Arde
A good idea to put a mechanical gauge on these Dodges regardless of what pressure they show. As inaccurate as many of them are, you don't really know what the pressure is till you double check them. Good oil pressure may be an illusion.
Old May 30, 2014 | 09:24 AM
sully5981's Avatar
sully5981
replace the sending unit. That's what mine did too.
Hey what is the sending unit and is this bad for the engine? Mine just stays in the middle all the time unless I turn off the engine which it then goes to 0.
Old May 30, 2014 | 11:55 AM
Arde's Avatar
Arde
Sending unit sends signal to pressure gauge so it knows what pressure to show. A bad one isn't bad for the engine, but low oil pressure is. You could change yours out and see if it reads proper pressure, if not, install a mechanical gauge. It's screwed into the top of the block just to the passenger side of the distributor. A bit of trouble to get to. There's a special socket for it, or you can get it with an open end wrench angled downward toward the transmission. You also can just break the plastic top off the old one and just use a socket, but you still have to get the new one in.
Old May 30, 2014 | 12:09 PM
Originally Posted by Arde
Sending unit sends signal to pressure gauge so it knows what pressure to show. A bad one isn't bad for the engine, but low oil pressure is. You could change yours out and see if it reads proper pressure, if not, install a mechanical gauge. It's screwed into the top of the block just to the drivers side of the distributor. A bit of trouble to get to. There's a special socket for it, or you can get it with an open end wrench angled downward toward the transmission. You also can just break the plastic top off the old one and just use a socket, but you still have to get the new one in.
Passenger side of the distributor.
Old May 30, 2014 | 01:16 PM
Arde's Avatar
Arde
Right, haven't had quite enough coffee.
Fixed it.
Old May 30, 2014 | 03:21 PM
Fixed it.
Familiar with that...... You don't EVEN want to talk to me till I am on my second cup.
Old May 30, 2014 | 11:44 PM
Blue Mopar01's Avatar
Blue Mopar01
A stubby 1 1/16 wrench works...well for me I chopped an 1 1/16 to a stubby and used it for mine
Old May 31, 2014 | 01:23 PM
sully5981's Avatar
sully5981
holy crap that was a pain in the ***. Well i swapped out the oil pressure sending unit. (used vice scrips to take it off then spent $9 on the tool at the store to put it back since i had such a pain the *** taking it off)
well anyways. My truck still has the oil gauge smack in the middle when the truck runs. It has been that way since I bought it a year ago and I have not had any issues. How hard would it be to slap on a mechanical oil pressure gauge?
