Oil pressure questions
Old May 24, 2014 | 01:26 PM
Blue Mopar01's Avatar
Blue Mopar01
Default Oil pressure questions
Lately I've been watching my oil pressure and to me it doesn't seem right. Under throttle it'll go up to normal pressure. When driving at 60-65 mph it'll stay around 50-60 (judging the gauge) and other times it'll go down and stay at 40. If I deaccelerate it won't go down and will stay around 40-60 (Whatever pressure I was at at highway speeds). I'm kinda worried I have a bearing failure or something with the oil pump. Anybody help out? I can explain more if neeeded
Old May 24, 2014 | 01:36 PM
Lots of things influence oil pressure. Engine RPM being right there at the top of the list. But, even simple things such as the age of the oil will have an affect.
Basically, if you have better than 10PSI at idle, and then about 10 PSI more per 1000 RPM, up to about 60 PSI max, everything is hunky dory.
Old May 24, 2014 | 06:39 PM
Darren270's Avatar
Darren270
You think thats odd, mine stays at around 40-42 at all speeds no matter if I'm idling or how hard I accelerate!
Old May 24, 2014 | 10:30 PM
replace the sending unit. That's what mine did too.
Old May 25, 2014 | 02:20 AM
djbucky3's Avatar
djbucky3
Since we have HeyYou involved already, might as well ask.. What if the truck seems to be always running high? I have never really paid that much attention to the oil pressure, but it does always seem to be up at 60 or above.. (depending on how you read these gauges..) But never dropping below 40
Old May 25, 2014 | 09:05 AM
Blue Mopar01
Alright sounds good I just didn't want to keep worrying with my new motor. Thanks for the reassurance HeyYou!
Old May 25, 2014 | 11:33 AM
That isn't a problem. You have good oil pressure. If you don't trust the gauge, you can stick a mechanical on there for a bit, to see what is REALLY happening...... but, oil pressure that good generally implies that the bearings and such are still in great shape.
Old May 25, 2014 | 03:20 PM
Dakota1089's Avatar
Dakota1089
Mine basically acts like yours which from my understanding was normal. Sits around 30-40 at stop or idle and around 50-60 during regular driving.
Old May 26, 2014 | 12:28 AM
djbucky3's Avatar
djbucky3
You just made my day
Old May 26, 2014 | 04:08 AM
gerry92's Avatar
gerry92
That should explain, thanks.
