Intermittent crank no start
Old May 26, 2014 | 03:00 PM
97ramrod1500's Avatar
97ramrod1500
Default Intermittent crank no start
My 97 ram 1500 ran great all winter besides the poor heat. Truck would start up right away every time I turned the key. Towards the end of winter the truck would start up then wouldn't hold idle without my help which I believe I have to clean or replace the iac again. The last snow storm I went to start my truck in the morning and it just cranked and cranked but would not start. I replaced the fuel pump last fall right before winter. When the engine does start it runs great. The engine is a 5.2 with 235,000miles.
Old May 26, 2014 | 09:07 PM
When it doesn't want to start, do you hear the fuel pump prime?
Old May 26, 2014 | 09:51 PM
97ramrod1500
Yes I do, and I also checked fuel pressure both when it starts and doesn't start and there's no difference.
Old May 26, 2014 | 10:23 PM
So it's either spark, or injector pulse. Spark is easy to test. See if it's there.
Old May 27, 2014 | 07:26 PM
97ramrod1500
everytime I went to start it the past couple days it fired right up, once it fails then I will check spark. whats the easiest way? connect a spark plug directly to the distributor lead from the coil?
assuming I have no spark where do I go from there? bad coil? bad crank sensor?
Old May 27, 2014 | 07:43 PM
Just pull a plug wire of number 2 or 4, right there easy to reach.
First suspect would be crank sensor.
Old Jun 4, 2014 | 09:26 PM
97ramrod1500
Well it's been a couple weeks now and it seems my truck will start great every time until it rains. Once it's damp outside it is just wont start. Monday after about 15min of on and off cranking it fired. Ran super rough and stumbled for a couple minutes then ran like a charm. Once it started to warm up it ran excellent. When it was just cranking I stopped and listened for the fuel pump every time I cycled the key and I could clearly hear it running. I'm starting to just get irritated.
Old Jun 5, 2014 | 12:15 PM
Next dry day you get, take a spray bottle, with water, mist the plug wires good, see if the truck starts. If it doesn't, replace the plug wires.
Old Jun 8, 2014 | 09:15 PM
97ramrod1500
Finally had a chance to do this today, truck started right up, I misted some water on the wires and sure enough 1 of the wires near the distributor cap started arching to the nearest hose. Then I opened the throttle slightly while the wires were still soaked and 3 or 4 of the wires arched and the truck died. It didn't start until the wires dried. So I ordered a new set of wires. I didn't even think of them as being a problem since they have less than 30,000 miles on them and are only 3 years old. Thanks very much!
Old Jun 9, 2014 | 11:59 AM
I love the easy ones. Glad ya got it fixed.
