Jacking up my 4x4 the proper way?
Old May 29, 2014 | 09:13 PM
jmhd1989's Avatar
jmhd1989
Default Jacking up my 4x4 the proper way?
I have always been told not to jack up a vehicle be the differential. But how do you lift up the entire front end or rear end without jacking from the center of the axle? i just need it up long enough to get the jack stands under the outer sides of the axles.
Old May 29, 2014 | 09:16 PM
Ham Bone's Avatar
Ham Bone
I Jack up one side at time using bottle Jack's on the tube. Becuase I don't have a floor Jack.
I've seen plenty of people Jack up by the pumpkin. It's a solid front axle. Really doubt youre gonna hurt it.
Old May 29, 2014 | 09:41 PM
stewie01's Avatar
stewie01
If you want both sides up at the same time you're gonna have to use the pumpkin....
jmhd1989's Avatar
jmhd1989
i tend to think the same but "supposedly" there are stories of failures.
Old May 29, 2014 | 10:32 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
there is no problem lifting on the diff pot aslong as you don't have a heavy load in the truck.
Old May 30, 2014 | 08:28 AM
If a differential failed because someone was using it as a jack point, there was something else bad wrong going on there. The diff is DESIGNED to support the weight of the truck.... if it won't, I would rather find out on a jack, than on the freeway at 70 MPH.
Old May 30, 2014 | 08:58 AM
that_guy's Avatar
that_guy
+1
My dad and grandpap have always been jacking up their cars by the differential, and since they haven't ever had issues with it in 50+ years that's what I do too. Now the trucks with the off center front diff won't work like that due to balance, but the axle works for those.
Old May 30, 2014 | 11:00 AM
kejobe's Avatar
kejobe
As stated, been done for years by myself and thousands (at least) others. It's not a problem.
