1995 dodge ram 1500 5.9 pinging under load
Haven't posted in a couple months. Did an engine swap and the oil consumption is back....... 167k miles on the motor and the same symptoms I feel are coming back that blew a piston ring in my old motor...... When I accelerate a little hard it seems like it bogs down and hesitates for a moment then all of a sudden accelerates really fast. While its bogging and hesitating there's a pinging noise coming from the motor. Gets louder and louder the longer and harder I get on the throttle. Don't want to go through another motor. I hope it's a sensor or something simple. There's new plugs, wires, plenum, headers, Cold air intake, and oil pump. The fuel pump is about 2 years old. Also when it goes into over drive at about 55 mph is starts to shake a tad and won't go over 65 mph without the pinging getting out of hand. Maybe an o2 sensor or fowled plug? Compression is good but still consuming a lot of oil. Please help! I love my ram!
Yes, IAC, Map Sensor, Fuel injectors, and o2 sensor were used from the old one. The cam sensor, Plenum, and Throttle position sensor are a few months old.
The crank sensor is about 5 months old. Codes are 37 and 24(only sometimes) check engine light will randomly come on. It's pulling up code 27 also which is injector # control circuit? I do smell gas when I've been driving around for awhile. Not to mention when It goes into overdrive at about 55 mph it shakes when I give it gas. Plus the pinging and everything I said before.
I would check or replace the map sensor, and if the 02 sensors are original or have a lot of miles on them, then there bad. The map sensor controls timing and fuel delivery to a point, and if it goes bad it could cause your engine to run lean or bog down.
Trending Topics
I honestly have no idea. How do I check? I have been told that code comes up often on dodges.
