Igniton Key Have Chip?
Old Jun 10, 2014 | 10:23 PM
Panfailure's Avatar
Panfailure
Default Igniton Key Have Chip?
I just acquired a 1999 Ram 1500 built in June which still should be a 1999?
I only have a key that was made at a key shop. Did it come factory with a chipped key? How do I find out without the original?
Have a no start issue and want to make sure it's not the key before I check everything else.
Thanks, Jeff
Old Jun 10, 2014 | 10:30 PM
frankie_b_jr's Avatar
frankie_b_jr
No smart keys, thankfully. Is it turning over? Can you hear the fuel pump for a few seconds when you turn the key on? Some people a lot smarter than me will probably chime in with more ideas for you.
Old Jun 10, 2014 | 10:42 PM
Ham Bone's Avatar
Ham Bone
well we some more symptoms to try and diagnose this.
If the key turns the ignition it is not the problem
Old Jun 10, 2014 | 11:04 PM
Panfailure's Avatar
Panfailure
Thanks guys!
Yea it turns over just a no spark issue. Didn't want to get started checking things until I knew about the ignition key. Will start the diagnosing tomorrow.
Thanks, Jeff
Old Jun 11, 2014 | 11:43 AM
Didn't the newer trucks have some variety of VATS? (chip in the key??)
Old Jun 11, 2014 | 12:28 PM
Ham Bone's Avatar
Ham Bone
My 01 doesn't. I can pull the key out driving down the road.
Old Jun 11, 2014 | 02:36 PM
Ok, system is called "VTSS", and no chip in the key is involved. (looked in the manual....)
Old Jun 11, 2014 | 10:19 PM
i4got68's Avatar
i4got68
Check your grounds, the coil, dist cap, plug wires, etc. The basics. I know my truck won't start when it rains due to a bad coil unless I leave a trouble lamp on it when it rains.
Old Jun 12, 2014 | 08:18 AM
Just curious, why'd you buy a truck that wont start?
Old Jun 14, 2014 | 11:19 PM
Panfailure's Avatar
Panfailure
It was cheap!
Ok so I have done some trouble shooting and come up with either the cam or crank sensor. How do you check these to see if they are bad.
I downloaded the FSM and it said on the CKS that it should have 5 volts then 0. Can I hook a VOM to the two wires and have someone crank to see if it shows 5 then 0 volts?
What about the cam position sensor/plate any way to check it?
I should add that I have power to the coil and injectors while cranking but no spark from coil or plug wires. It had a new coil on it when I bought it.
Thanks for the help!
Regards, Jeff
