front sway bar needed help
Old Jun 19, 2014 | 07:44 PM
ghostdodge's Avatar
ghostdodge
Originally Posted by AtomicDog
I have seen different style sway bar links for the 2nd gen trucks, which would imply at least two different style sway bars. It would be helpful for someone to post a photo of their front sway bar setup off their ORE truck to alleviate confusion and provide clarity to this topic.
the link on a reg.4x4 is straight,where the ore is straight on top where it connects to the sway bar and at a angle where it connects to the axle..
Old Jun 19, 2014 | 09:48 PM
AtomicDog's Avatar
AtomicDog
Sounds like the way mine is setup on my '96 Ram 2500 4x4. The bottom is a right angled ball joint type of connection at the axle and the top is straight. I had no issue finding replacement sway bar links at my local Pep Boys. I do recall that there were two different styles of sway bar links - ones like mine and straight ones.
Old Jun 19, 2014 | 09:52 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Originally Posted by Ham Bone
What do you mean it doesn't fit? How does it not fit?
You can't find one for it because there aren't any special pens for the ORE. they are all the same.
Really HB? That's definitely incorrect info.
OP and Veterans here -- Ever think to put "sway bar size" in the search bar?
https://dodgeforum.com/forum/search....archid=5184628
I do have recent pics posted in Corbo's thread of my front steering. Shows the sway bar to a certain extent. It's in the Gen Discussion subforum.
Old Jun 19, 2014 | 09:57 PM
Ham Bone's Avatar
Ham Bone
Ahhh I see. I assumed yours was some fancy aftermarket/fabbed version
Guess I should stop assuming
Old Jun 20, 2014 | 02:01 PM
Tasca Dodge Parts's Avatar
Tasca Dodge Parts
Former Vendor
Default Photos from the catalog...
Hope these help... They do show 2 types of sway bars.
Chris
Attached Thumbnails front sway bar needed help-01ram.jpg   front sway bar needed help-01ram2.jpg
Old Jun 20, 2014 | 03:53 PM
AtomicDog's Avatar
AtomicDog
Based upon those photos, looks to me as if 2WD trucks use the straight sway bar link setup and 4WD trucks use the lower 90 degree ball joint style sway bar link setup.
Old Jun 20, 2014 | 09:59 PM
oxymoron29's Avatar
oxymoron29
Perhaps the OP has been looking at the incorrect year sway bars at the JY? 94-97 end links are different than 98-01. See here for pics:
https://dodgeforum.com/forum/2nd-gen...with-lift.html
Old Jun 22, 2014 | 12:26 PM
ghostdodge's Avatar
ghostdodge
thanks for the help//yes i need the whole sway bar with the lower 90 degree ball joint style...
Old Jun 22, 2014 | 12:30 PM
ghostdodge's Avatar
ghostdodge
the previous owner pulled off the sway bar...but i cant tow due to the body sway when breaking down a hill.my truck is a beast when it tows but i need a sway bar bad...thanks to all for your help...
Old Jun 22, 2014 | 02:10 PM
Ham Bone's Avatar
Ham Bone
Where are you located? I think I have an extra sway bar laying around somewhere.
It did come off of a 2500 4x4. Looked the same as mine. Had the straight with the lower 90 degree end link.
