Burning Oil.
Old Jun 23, 2014 | 12:30 PM
98Dodgeram360V8Mag's Avatar
98Dodgeram360V8Mag
Electronic compression test??
What did your numbers look like? Think I would be real tempted to run the test with a gauge, dry, then wet, and see what happens. That sounds a LOT like bad rings.
Yep. And all of the numbers were in the low to mid 90's. I did use the gauge and on it the numbers were VERY good.
Old Jun 23, 2014 | 12:31 PM
98Dodgeram360V8Mag
And I thought the same thing.
Old Jun 23, 2014 | 01:04 PM
Low to mid 90's is below spec. 100 is considered the minimum......
Old Jun 23, 2014 | 02:40 PM
98Dodgeram360V8Mag
Hmm. When I did the tests I was taking mechanics college classes at the time and my teacher said the those numbers were fine. But on the gauge test I am wanting to say that the numbers were at an upwards of 175.
Old Jun 23, 2014 | 07:40 PM
jpsycoboy5's Avatar
jpsycoboy5
The easy solution check oil add when necessary. 5 quarts isn't terrible on my first ram I drove from Michigan to Kentucky with a car hauler and used 15 quarts of oil clogged the cat on that trip found out later on I had 2 dead cylinders rings were basically gone I drove it like that for another 10,000 miles before I swapped the motor.
Old Jun 24, 2014 | 12:26 AM
98Dodgeram360V8Mag
Wow. Haha.
Old Jun 24, 2014 | 10:37 AM
Numbers I quoted are direct from Chrysler.
175 PSI? I would hardly expect to see that from a new motor..... I would run the test again, post up the numbers. Let's see what ya get.
Old Jun 24, 2014 | 02:22 PM
98Dodgeram360V8Mag
Uhh I swear that's what it said. Lol
