5.9 Clutch Fan
Old Jun 23, 2014 | 07:58 PM
elmoe's Avatar
elmoe
Default 5.9 Clutch Fan
I have a 98 Wrangler with a 98 5.9 swapped in it. I replaced my radiator and now my fan will not fit. Does anyone know if someone makes a thin fan clutch that will thread on the water pump. I only have 3 inches between the radiator and water pump. My new radiator is about 1/4 deeper than the one I removed. I've looked at electric fans but can not find a thin one that has enough CFM in my opinion. Any help/advise will be appreciated.
Paul
Old Jun 24, 2014 | 10:44 AM
Did you get a different style radiator than stock? (guessing that's a yes....)
Taurus fan moves enough air, pretty hefty amp draw though. Not aware of any alternatives for the fan though.... can you alter your radiator mounts to move it forward some?
Old Jun 24, 2014 | 02:51 PM
Wildman4x4nut's Avatar
Wildman4x4nut
Veteran: Army
I have a 5.2 in my TJ and am in the middle of swapping in a 5.9 into it. I have been running electric fans from the get go. Can you send me some pictures so I can see what it is you're dealing with? You can email them to me , use the email in my sig or use a photo hosting program like photobucket and put them up on here.
You can sometimes get around the depth issue by mounting the fan a little lower than the water pump. By doing this the motor for the fan then has the area between the radiator and bottom pulley. That is how my Jeep is setup. The other thing I did was cut the threads off the end of the water pump.
Edit:
Also why did you change radiators? What radiator were you using in the first place?
Old Jun 24, 2014 | 09:16 PM
elmoe's Avatar
elmoe
I'm not sure of the original model of radiator that I had on it. I bought it used and it started to leak around the cap area. I bought an aluminum one from Champion. I found a Derale fan and shroud combo that's 3 inches thick that I may order. I put my motor mounts in the hole that Advance Adapters said to and did not think to test fit the radiator. I have no more than 3 and 1/4 inch between the water pump and radiator. I thought about cutting off the stud, but I think that I want to keep the mechanical fan if possible. I originally had a 19 inch fan and a pieced together shroud that kept it real cool 190-197. I didn't like the looks of the shroud so I went with a 5 blade fan and it kept it at normal TJ temps 205-210. My Jeep is not at my house but I'll try and get you some pics tomorrow. Thanks
Old Jun 24, 2014 | 09:27 PM
Spillage's Avatar
Spillage
Not a TJ, but I have two 16" e-fans (2024cfm ea) on my 5.2 ram (stock radiator).
I have one fan disconnected at the moment, and the other one keeps up at 180°F real easy at nothing over 60% speed and cycling.
Old Jun 30, 2014 | 06:22 PM
elmoe's Avatar
elmoe
I ordered a Derale two speed fan and shroud combo along with a Dakota Digital controller. I hope that it all fits in the space and keeps my Jeep cool. I will post the results when I get it all installed. Thanks for the help.
Old Jun 30, 2014 | 10:07 PM
archemedes74's Avatar
archemedes74
if it came down to it get a pusher fan, they aren't as efficient, but mount on the front of the rad (a lot of hot rodders use them)
