AXLE question
Old Jun 28, 2014 | 05:20 PM
Mutt Bryant's Avatar
Mutt Bryant
Default AXLE question
I got mil 36s on the dodge right now... If in the End I want 40's what gear shall be adequate. Could I run 4.88s decently with 40's? What about 5:13s? I want the low torque but I gotta make a desicion that works both ways. Also how much clearance height wise do i need based on my pic below. that's stock, no lift.
Old Jun 28, 2014 | 06:15 PM
Wildman4x4nut's Avatar
Wildman4x4nut
Veteran: Army
I'd go 5.13 for sure. With the 36" tires you might have slightly high rpms but with the 40" tires your engine & tranny will thank you. I'm running 5.13 gears and 38" tires and like the gearing a lot.
I can't tell you about the lift.
Old Jun 28, 2014 | 06:17 PM
I agree with Wildman, gear for the larger size tires, then when you do change, you won't have to spend that money again. (and it is not a particularly cheap endeavor....)
Old Jun 30, 2014 | 06:03 PM
Mutt Bryant
I like that idea. One more question (abit unrelated) My computer went out and I had to get a loaner. Thanks to this swap, my dash systems no longer work. I at least need the gas guage back. is there something I can do to add an aftermarket or something??
Old Jun 30, 2014 | 10:00 PM
What year PCM did you get as a "loaner"?
Old Jun 30, 2014 | 10:04 PM
Mutt Bryant
Psh heck if I know. It was real cheap. all I know is prob a 96 or so.
Old Jun 30, 2014 | 10:08 PM
And that is why nothing works. In 98, a LOT change in how things work. They went to a 'mini-network' in your truck, where everything talked to the central timer module (hub) and it talked to everything else. The older PCM doesn't tell the CTM anything at all, so, the CTM doesn't have a clue what to tell anything else. You need a 98 or newer PCM.
Old Jun 30, 2014 | 10:10 PM
archemedes74's Avatar
archemedes74
I'm surprised it even runs, wasn't '96 the weird computer year of obd 1.5?
Old Jun 30, 2014 | 10:13 PM
It's OBDII, after a fashion.... it still reads all the same sensors, and gives all the same outputs, so it will run the engine, but, none of the instruments will work, and I bet cruise doesn't either...
Old Jun 30, 2014 | 10:32 PM
Mutt Bryant
My cruise never worked :3 but ima prob change it after I save up
