front axle replacement
Old Jun 25, 2014 | 01:55 PM
ldsbro's Avatar
ldsbro
Default front axle replacement
Okay here goes I did a ball joint service to start and noticed just some fresh grease wasn't gonna cut it so I replaced them well turns out the press fit is none existent the inner c on the top port is over sized and bigger ball joints didn't help so now I'm stuck looking for a new front end been looking in salvage yards and Google with no luck any body else came across this problem have any advice would be helpfully
Old Jun 26, 2014 | 10:01 AM
All of the second gen 4x4's used the same front axle. (half tons) They should be relatively easy to find...... check craigslist for someone parting out a truck.
Old Jun 26, 2014 | 07:22 PM
TEDD's Avatar
TEDD
Same thing happened to my stock 44 before I upgraded to a 60. All I did is put 4 solid tacks from the ball joint housing to the inner c. The inner c is cast steel so no special rod or wire is needed, just make sure to let it cool in between tacks so you don't melt the Teflon liner in the balljoint. I wheeled the crap out of that axle and even bent the top of the c without my tacks breaking. When you have to replace the balljoint again just cut the tacks with a cutoff wheel and repeat. Worse case scenario at least your truck won't be down while you look for another axle. Good luck.
