idler pulley/belt question
Old Jun 25, 2014 | 11:07 PM
JackedUp4x4's Avatar
JackedUp4x4
Default idler pulley/belt question
Hey guys I replaced my idler pulley and belt today and when I reinstalled the pulley and belt, the belt hangs maybe a 1/8-1/4 off of the backside of the idler pulley.
Everything is installed correctly and I used the same bolt, washer, and metal spacer on backside of pulley that came off of the one I took off.
My question is how do I get the idler pulley to move that little bit towards the block? Its as tight as its going to get without breaking something or stripping the bolt.
Also, the metal spacer on the backside of the pulley, that does have to be reused, correct?
Thank you all in advance!
1998 ram 1500 318 5.2 V8
with A/C
Old Jun 26, 2014 | 09:47 AM
Belt shouldn't hang off the pulley..... that will eat it up in pretty short order. I think there is an 'alignment' pin on the tensioner, did that go into its little hole? Is the washer on the wrong side???
Old Jun 26, 2014 | 12:48 PM
JackedUp4x4
I replaced idler pulley not tensioner
I did tensioner a few weeks ago and yeah it fit in the grooves before I tightend it up
The washer is on the right side because I never took it off if the bolt when I removed the old one
Old Jun 26, 2014 | 01:55 PM
Ooops. Need to read a bit more carefully methinks.
Compare the new, and old pulleys. Do they look the same??
Old Jun 26, 2014 | 02:05 PM
JackedUp4x4
Its okay
Yes the pulleys are the same. Same width, length, ect
Old Jun 26, 2014 | 04:45 PM
Tasca Dodge Parts's Avatar
Tasca Dodge Parts
Former Vendor
I would guess where the bearing is in the pulley is different or has a spacer in it? any pictures?
Chris
Old Jun 26, 2014 | 05:24 PM
Metal or plastic? Can you just flip it around?
Old Jun 26, 2014 | 10:25 PM
JackedUp4x4
I figured it out everyone, I made a rookie mistake and didn't read the box the pulley came in. It says right on the box to not use the factory spacer or dust shield because they are pre greased bearings and is not needed and it also says it can cause interference which it did.
Thank you all for the answers and sorry for wasting your time.
