Trail Carnage.. help :\
Old Jul 19, 2014 | 07:08 PM
  #31
stewie01's Avatar
stewie01
Originally Posted by Thornloe Pride
Yeah makes sense just have to figure out how to get it there lol
That will be fun.
Got a friend with a (big) car trailer?
Old Jul 19, 2014 | 08:19 PM
  #32
Thornloe Pride's Avatar
Thornloe Pride
Originally Posted by stewie01
That will be fun.
No not really
Old Jul 19, 2014 | 08:46 PM
  #33
Thornloe Pride
Another video for your guys. This time I didn't go around the yard instead I went down the road. Worked great for probably 3 miles. Shifted through every gear even OD and R. No problem and no slipping Then this happened. This is the huge drag I was talking about. It appears to happen only when tranny gets hot. At the end I even put it in 4L to show you guys just how much resistance there is. When I got back I checked my fluid and it is F'IN HOT and there's a white line of pasty stuff here and there. I still have no idea how I drove home 60 miles and why it didn't do this.
Old Jul 19, 2014 | 09:00 PM
  #34
stewie01's Avatar
stewie01
Check out the check valve delete thread, remove the valve if your truck still has it. See if that improves the cooling.
I wouldn't drive it too much more, if the fluid is getting that hot you're burning up the transmission.
Old Jul 19, 2014 | 09:05 PM
  #35
Thornloe Pride
Yeah no I'm done driving it just wanted that vid because there's nobody around to give me a hand or ideas. Ill try that tomorrow.
Old Jul 20, 2014 | 09:52 AM
  #36
Trans is slipping. Time for a rebuild.
Old Jul 20, 2014 | 02:35 PM
  #37
Thornloe Pride
I read in anther thread about a guy having a very similar problem and it was his torque converter. Is that possible in my case
Old Jul 20, 2014 | 04:40 PM
  #38
ryan0714's Avatar
ryan0714
holy hell thats just sad. its like the trans went into LIMP MODE. now you just gotta figure out is why...
Old Jul 20, 2014 | 05:26 PM
  #39
It's entirely possible the t/c is causing the problem, trouble is, when it fails like that, it tends to scatter crap all thru the trans, so, just replacing the t/c is only a very temporary fix, and throws away yet another t/c. (it is basically impossible to ensure you have cleaned all the crap out of one, without cutting it open.....)
I would either rebuild the current trans, or, swap in another one. (flush the cooler lines REALLY well.) I don't think this is going to be an 'easy' fix.
Old Jul 20, 2014 | 05:36 PM
  #40
stewie01's Avatar
stewie01
Shall I say it again? 5spd swap!
