Slow Start, replaced a ton of parts still doing it
Old Aug 15, 2014 | 10:38 AM
  #21
No MAF on our trucks. Speed-density system, use a MAP sensor.
Old Aug 15, 2014 | 05:38 PM
  #22
Twmays's Avatar
Twmays
Po-tay-toe, pah-tah-toe. fat finger typo strikes again.
Either way, I thought I read somewhere that stop/can't restart issue was caused by a failing ma*P* sensor. Is that right?
Old Sep 8, 2014 | 11:51 AM
  #23
dodgeit1999's Avatar
dodgeit1999
So was the haed to start ever resolved ???
Old Sep 12, 2014 | 10:45 AM
  #24
hawi's Avatar
hawi
i didn't see it mentioned that you'd replaced the fuel filter..? just a thought.
Old Sep 12, 2014 | 10:18 PM
  #25
Ram Driver's Avatar
Ram Driver
Our trucks don`t have a fuel filter.
Old Sep 13, 2014 | 10:59 AM
  #26
We have one, it is just pretty much 'non-serviceable.'
Old Sep 13, 2014 | 05:22 PM
  #27
kgilhooley31's Avatar
kgilhooley31
Check your engine block grounding cable that goes directly to the negative battery terminal hookup. Mine was only alittle loose and I had this same exact problem. The starter couldn't push enough amps quickly enough through it and it would sputter and cough until it jumped to life. Other times (I guess depending on a good connection by happenstance) it would start like a charm. I actually just replaced the whole ground wire cause was alittle corroded too.
