new oil pump and screen, no pressure at idle
Old Jul 21, 2014 | 07:21 PM
Ham Bone's Avatar
Ham Bone
If you actually had ZERO oil pressure your engine would be making such a racket you would immediately cut it off and think you destroyed the whole engine.
Old Jul 21, 2014 | 10:40 PM
frankie_b_jr's Avatar
frankie_b_jr
Don't trust it without a gauge. I thought my sensor was off for a little while, then started hearing the bad noises, after a few months of random oil pressure loss. Finally got a full blown knock pulling into my driveway so I pulled the pan and checked bearings. After looking at this poor motor I am thoroughly impressed. #1 was the noise maker I think, but why this thing didn't sound like a Volkswagen TDI is beyond me. All of the top half (rod side) of the bearings were into the copper at least a little bit.
Moral of the story is check your stuff and trust your instincts. If something feels wrong, it probably is.
Old Jul 22, 2014 | 06:08 AM
drtydn's Avatar
drtydn
Originally Posted by JSTMoto
Was this the same as before you did the pump and screen change?
Also, does it register pressure on cold start up?
i do read oil pressure before it gets to operating temperature. and no, before i changed the pump i had zero pressure all the way around.
also guys, i did do my head gaskets just before this happened, could i have messed something up?
Old Jul 22, 2014 | 06:12 AM
drtydn's Avatar
drtydn
im going to change the oil sensor as soon as my pay check hits the account. im just wondering what to do next if thatrs not the issue
Old Jul 22, 2014 | 06:18 AM
drtydn's Avatar
drtydn
this is what its doing
Old Jul 22, 2014 | 08:57 AM
Ram Driver's Avatar
Ram Driver
looks like a bad sending unit to me. I had an oil pressure sending unit go bad on a chevy service truck I used to drive, and it did the same thing. I replaced the sending unit and that solved the problem.
Old Jul 22, 2014 | 10:21 PM
ClubCab5.9's Avatar
ClubCab5.9
Cant wait to see some pictures. You are going to take some pic's to help out right?
Old Jul 23, 2014 | 08:19 AM
drtydn's Avatar
drtydn
what work do you want pics of?
Old Jul 23, 2014 | 10:58 AM
drtydn's Avatar
drtydn
ok guys, update time! i just got done putting a new oil pressure switch in (i rate it amongst some of the top most uncomfortable moments when working on my truck) and it seems to have fixed my problem. HOWEVER, now only when coming to a stop does it go down to zero. when i put in in neutral it jumps right back up. could this be a low oil issue? i need to change it but i plan on doing a flush first. then new oil filter and oil... the engine even seems to sound like its running better. also it wouldent hurt for some new plugs (also picked up today, just waiting on the rain to stop... gotta love the southern Indiana)
Old Jul 23, 2014 | 01:44 PM
Check your oil level and see......
And yeah, it's almost as much fun as doing the distributor cap.......
If you barely bring the RPM up, and the gauge jumps from zero to 30 or more, chances are good that the new sending unit is bad as well. (wouldn't be the first time I got a bad part, right out of the box.)
