edlebrock shorty headers mounting question
Old Oct 21, 2005 | 02:37 PM
shott8283's Avatar
shott8283
Default edlebrock shorty headers mounting question
for all you that put these headers on your rams.. got a question... i finally got all my parts in and ill shortly start puting my new new exhaust on. i was looking at the header mounting bolts that came with it .. i got 11 locking washers and 8 black regualar washers that some how go on the bolts to attacht the headers to the heads.... what washers did you guys use on what holes? i got 12 total bolts to use... but what mixture did you guys use with these washers? any help would be great!
Old Oct 21, 2005 | 02:39 PM
shott8283's Avatar
shott8283
Default RE: edlebrock shorty headers mounting question
correction.. i got 12 locking washers... the dog ran off with one
Old Oct 21, 2005 | 05:22 PM
Silver_Dodge's Avatar
Silver_Dodge
I think the instructions that came with mine said to use the black washers on the holes that are cut out on the side. If you look at the header, some holes are just drilled (so there is metal all around), and some are basically shaped like a C (open on one side). The black washers go on the C's. The order is bolt head - locking washer - black washer - header surface.
If you keep the stock studs (should be 2 on each side), you will not need to use all the bolts provided. I kept the studs at first, but then replaced them with new bolts after I saw how they looked. Also, bolts that take an allen head work much better then the set that comes with the header. They are easier to get to (escpecially in the back) with an allen head then with a wrench. If you decide to use a wrench, a ratcheting wrench (not a ratchet and socket) works best in that tight space.
Let me know if you have any other questions. I just did mine about 3-4 months ago. It is pretty easy.
Old Oct 21, 2005 | 07:35 PM
shott8283's Avatar
shott8283
thanks silver... thats what i figured ... the open holes were for the black washers b/c the amount of washers per the amount of open holes matched up... and did you have a hard time getting the led o rings on? did you have to tap them on with a mallet? thanks again!!!!! im gonna use the new bolts that came with them b.c my old ones are in bad shape.. and ill look into the allen key ones...sounds like a good idea.. thanks agian!
Old Oct 21, 2005 | 08:16 PM
blaze_tylr's Avatar
blaze_tylr
How much did they run you ? Any performance differnce ?
Old Oct 21, 2005 | 08:27 PM
Silver_Dodge
ORIGINAL: shott8283
.....did you have a hard time getting the led o rings on? did you have to tap them on with a mallet?
I assume you mean the donut gaskets that go to the y-pipe connections. No, mine slide right on, and were even tight enough that they didn't slide off during install. I would be very careful taping them with a mallet. If you damage them at all, you could have an exhaust leak. Let me know if you have any other questions.
ORIGINAL: blaze_tylr
They were less then $400 shipped, which is pretty good for ceramic's I thought. I definelty noticed a difference, but only on the top end. Really made a noticable difference the first time I towed my camper up a mountain pass.
