99' 2500 v10 - Front Hubs Very Hot - Replaced Calipers & Master Cylinder - Need Input
Old Sep 13, 2014 | 04:46 PM
warreng5995's Avatar
warreng5995
Originally Posted by AtomicDog
Wonder if your brake fluid is contaminated - might want to flush your brake lines completely and install new fluid - personally, I used DOT4 brake fluid.
I know of DOT 3 and DOT 5 (which is a synthetic that will not absorb water) brake fluids.
I also know that DOT 3 can NOT be mixed with DOT 5.
I used DOT 5 in a couple military trucks, as that is what is called for and what was used in them to start with. I believe that some (or maybe many) motorcycles use DOT 5.
What exactly is DOT 4?
Can it be used in a DOT 3 System? (I assume it can from your statement)
Can it be mixed with DOT 3 fluid? As in if you drain a system, the traces of DOT 3 fluid that would be left coating the inside of the lines and cylinders and such?
And what in your opinion makes it better than DOT 3?
Old Sep 13, 2014 | 08:07 PM
AtomicDog's Avatar
AtomicDog
DOT4 can be mixed with DOT3. I use DOT4 as it has a higher boiling point than DOT3.
