transmission line
Old Sep 17, 2014 | 07:48 PM
bigaaron's Avatar
bigaaron
Default transmission line
tranny line coming out of the radiator is leaking at the female connector. THis is the push lock connector that uses the special release tool. Issue: My line is a short run to the hard line with a threaded bulk head fitting. Looks like the check valve was deleted before I bought it, but I cannot fing this line. I can find the entire line, but I was hoping just to get the rubber line. Any advice?
Old Sep 17, 2014 | 10:18 PM
Look in the FAQ/DIY section for the 'Check valve delete' thread. Several alternatives there.
Old Oct 12, 2014 | 09:31 AM
bigaaron's Avatar
bigaaron
Default done
thanks for the info Hey you. I cut my cost to about $20 using 2 fittinggs and a piece of tranny hose. Repaired following the advice on the FYI / DIY section
