Transfer case ?
Old Oct 3, 2014 | 09:58 PM
getdown78's Avatar
getdown78
Default Transfer case ?
Was driving my truck to work today and it started vibrating really bad so i turned around headed back home and then it got worse so i pulled over and looked under the truck and the t-case had came apart behind the front shaft yoke ? My ? is what yr t-case will fit my 96 r1500 auto ?
Old Oct 4, 2014 | 08:37 AM
Any t-case from a 1500 from 94-97 with a v-8, and auto, will bolt right in. 98 and up will also bolt in, but, the shift pattern is different, and, they have no provision for the VSS, so, your speedometer won't work...... (so basically, 98 and up really won't work.)
Old Oct 6, 2014 | 07:43 PM
getdown78's Avatar
getdown78
Ok, I found a 241 DLD in a 96 2500 5.9 auto but will it fit my truck ? The tailhousing is gone so will my tailhousing fit ?
Old Oct 6, 2014 | 09:08 PM
Think driveshaft length may be a problem, and possibly the mounting flange for the front driveshaft..... No clue if the tailshaft will swap over, but, I wouldn't hold my breath.
Old Oct 7, 2014 | 01:15 AM
Ham Bone's Avatar
Ham Bone
Front driveshaft will bolt up. But may be too long.
No idea about the tail housing
Old Oct 7, 2014 | 01:13 PM
merc225hp's Avatar
merc225hp
When I changed over to the 241DLD I had no driveshaft length or flange problems what so ever. Nothing need to be changed at all 100% bolt in job. I had to shorten the rear Ds because of the 60 install.
This might help
Left xcase in photo is a 231DLD out of a 96 1500 with a 46RE auto, one on the right is a 241DLD out of a 95 1500 with a 46RH auto. These do not interchange due to the input hub/shaft length.
Old Oct 7, 2014 | 10:02 PM
getdown78's Avatar
getdown78
What did the a v8 dakota have ?
Old Oct 8, 2014 | 11:54 PM
getdown78's Avatar
getdown78
What is the difference between the 231 and 241 ?
Old Oct 9, 2014 | 07:59 AM
241 is a physically larger case, wider chain, more gears in the planetaries, basically, it is a heavier duty t-case.
Old Oct 11, 2014 | 02:28 PM
getdown78's Avatar
getdown78
Ok so i found a t-case out of a 2000 1500 5.2 auto but will it fit my 96 ?
